RaySwitchMTL with Corona Light material problem
Hi
I want to use Corona Ray Switch material in order to lit the scene with emitting light mesh and to use material with self illumination to override direct/reflect/refract appearance of this mesh. There is no problem with reflect/refract override, but it doesn’t work with direct override material - it’s always gets light from the Light material and looks overburned.
On attached picture you can see example of this problem - sphere has CoronaRaySwitch material, box on foreground has refractive material, box on background has reflective material.
I don’t know is it a bug or just matter of some specific settings, but would be grateful to get some help
This is a known limitation.
“Light emitters cannot be ray-switched (example: light material which is directly visible as black, but emits blue light).”
Source: https://coronarenderer.freshdesk.com/support/solutions/articles/5000516180
