RCM Status
I need help!
I have installed Vray for rhino 3.0 but when i turn on Rhino it load everything except this RCM ( it says--- Failed to read registryfor RCM Status--- RCM mapping channel will be unavaible ).
This give me many problems with rendering…does any of you know what to do???
Se poi rispondete in italiano sarebbe il top!!!
Re: RCM Status
Check the McNeel wiki for RDK updates. There should be a download that will solve the problem. RCM got changed to RDK a few months back, so thats why you need to search for RDK
Re: RCM Status
I think some other users have had this problem after installing VfR4 - i think the RDK installer that our VfR4 installs may remove the older RCM stuff. Perhaps if you repair your VfR3 install it will resolve that issue? Also - when we get the VfR3 update out this issue should no longer trouble you, as our VfR3 will be using the new RDK as well.
