re-entering license, up to 10 times a day
Hi
On one of my render notes I have to re-enter my corona license sometimes up to 10 times a day.
Does someone knows a solution so that that computer will remember my license?
I already have reinstalled 3DS Max and corona, but it didn’t solve it. Next step would be a full clean install of windows.
greez
Would be faster to open support ticket: https://coronarenderer.freshdesk.com/support/tickets/new
hi, are you using 1.5 hotfix2? It solves a problem that could be causing this
If it doesn’t work, try to delete CoronaRenderer folder in your local appdata folder (“C:\Users*YOUR_USERNAME*\AppData\Local\CoronaRenderer”). This is a hidden folder so don’t forget to display them in the explorer. It worked for me some time ago.
Yes I have installed 1.5 hotfix (a couple of times). Wil try the appdata folder.
Keep you updated!
have you installed hotfix 2 though? It was not fixed in hotfix 1
Yess sorry meant hotfix 2 :smiley:
Update:
It kept happening after deleting the files from appdata …
So dit a fresh install of windows and he hasn’t asked for a license since! Yeah except when installing corona :smiley:
