RE: Render Size Limit Problem
Lately a funny thing is happening. No matter what I set the render size to be, it defaults to 1600x1200 if I try to make a larger rendering. If I set a smaller size, it renders at the specified size. But it won’t let me render larger than 1600x1200. Is there a way to fix this. It is really in convenient. Also, I have a final review coming up and was hoping to make a large format render but as of now, I cannot.
Thanks,
Joe
Re: RE: Render Size Limit Problem
Can you post a screenshot of your “Output” panel?
There’s a resolution limit on the older educational versions. Upgrade to the new version and you won’t have that issue.
