Subject: V-Ray Light remains visible in render despite “Invisible” being enabled
Vantage Version: 3.2 (Build 4267797)
Host App & Version: 3ds Max 2023
V-Ray Version: V-Ray 7, Update 2
GPU / Driver Version: NVIDIA RTX A6000
Description
In Chaos Vantage 3.2, V-Ray Lights (specifically sphere lights) are appearing as solid white/emissive shapes in the final render. This occurs even when the “Invisible” parameter is checked within the V-Ray Light settings in the host application prior.
Steps to Reproduce
- Create a V-Ray Light (Plane/Disk/Sphere) in the host application.
- In the Light Parameters, under the “Options” rollout, check Invisible.
- Start a Live Link session or export a .vrscene and open it in Vantage 3.2.
- Observe that the light source geometry is visible as a primary ray, rather than being hidden.
Discrepancy Detail:
- Viewport Behavior: Light source is correctly hidden (Invisible = On).
- Final Render Behavior: Light source appears as a solid white/emissive object.
- Specific Trigger: This occurs consistently when Clay Mode is active with “Use Reflection” toggled ON.
- Confirmed: The light is invisible in “Normals” mode but visible in the final .png/.exr output.
Expected Result
The light should contribute to the scene’s illumination and reflections (if enabled), but the light source geometry itself should be invisible to the camera.
Actual Result
The light source geometry is rendered as a flat, visible shape, refer to the attached image.
