Hi Team,
For me, if you add :
1/ Zoom in IPR
2/ Pause interactive rendering
3/ NBr pass in interactive rendering
You have my monthly money for many years !
Franck
Hello, I will allow my self to fulfil your request.
Just “Clone rendered frame window” (the max icon in VFB) there you can zoom in.
Im guessing you want to “make pause”, change a fiew things and “unpause”?
That would require re/render of the scene anyway, so the only benefit would be gething your memory cluged especialy that IR is quite fast and responsive anyway.
- Nbr? You mean number? There is a setting for that. Render Setup > Performance > Performance Settings > Interactive Rendering: Max Passes.
Id suggest contacting Adam Hotovy to talk about your payment plan, have a nice day.
As Tanakov said, the features you listed seem to be already implemented. ![]()
Ad1. You can also use 3ds Max blowup rendering for this - it works with IR
Ad2. You can click on the small Corona icon in the IR, and you will get a menu with additional options
Ad3. If you want to see the number of passes - just enable render stamp in the system tab. If you want to limit passes in the IR - what Tanakov said.
