Hi all,
Have any of you guys tried the USD workflow? I have never used the USD files but from what I understood it is type of file that Maya can process very fast, and more importantly it is editable directly from the scene, am I correct?
For bigger scene we usually try to use PROXIES and Maya References but I find that editing references, even moving an object can cause a lot of troubles to the point when it makes the heavy Maya scene almost unusable.
Are USDs a holy grail when working with big scenes? I am talking about ones that takes up to 120GB of RAM to render.
Since the V-Ray USD support is new, did you any main issues with it?
As I understand it you wouldn’t want to use USD to replace a proxy tree unless you wanted to edit the tree to have a different look. A USD animated character could have many different clothes and props which can be swapped out even all the way down to texture placement. I still use scene assembly and dont really feel the need to use USD especially for a single user.
For massive scenes I always use a combination of Scene assembly, I can swap out a proxy for the Maya scene file or low res version to bounding box. At render time you just set the Scene assembly render settings to Custom then set your Representation label (In my case I label every asset to “proxy”) This loads up the proxies at render time.
Hi @stezza , thanks for your reply. I am in Archviz field and I am looking to optimize our scene for the best performance / cooperation possiblites.
I am slowly getting into Scene Assembly, so far I love the viewport performance of GPU Cache :), although I am not able to get it working with VRay Proxy, the moment I choose .abc file to represent Proxy in the viewport, I lose all the proxies instances.
Hi there, you need to set the path to the Maya scene file which holds the proxy. So when you creat your scene definition you can link in the saved Maya scene file, along with gpu cache, bounding box or any variant you need.
1. When you make your TreeProxy.mb, make sure you have “Automatically create proxies” at the bottom of the Create V-Ray Proxy panel.
This will create the proxy within the scene with all textures connected and use this scene file to be part of your assembly definition node.
2. If you want to duplicate that tree once it is part of the assembly reference node you need to make sure you use "Duplicate Special options turn on Duplicate input graph.
