I am working on a arch-viz project and need some advice. Usually I stick with still images. This client wants to be
able to “cruise/move” around the scene on their computer. Originally, I was going to use PANO2VR, but now they want to be able to go all around the site.
It is an exterior project on the coast, and the grade has a significant slop down to the sea. They want to be able to go around and look at the building from all directions.
Looking up at sky or down at ground is not priority, but some up/down viewing is be okay.
Other than doing a series of different static views, or using PANO2VR, are there any other methods to produce such a deliverable?
I can do this easily within 3dsmax using my Spacepilot, but am unsure about how to get it to the end users…
Set it up nice in max. Bake all stuff to geometry. Load it in game engine. Export as simple game. Give them gun and let them have a run around in UDK or Crysis with baked textures. But that is a lot to do…
Game engines - interesting idea, totally new to me…
I thought I had seen on the forum some time ago, a sort of PDF you could make that would allow some pan/zoom/navigation, but I cannot find the thread.
Along the same lines of Lumion is Realis3d. They recently updated their free viewer to support the oculus rift. Considerably less expensive than Lumion…but Lumion has a huge library of diverse content. It is based on Unity, just makes the process a bit simpler. I believe it is still in beta, so there is that to consider also.
EDIT: Would probably be worth the time and effort if you have some to spare to learn the process for bringing content into Unreal Engine 4 since it is so affordable now, and Architectural Visualization is defined as exempt of their royalty charge in their terms of use…and the visuals are typically very impressive.
