Realflow and Vray DR Problem
i just installed the realflow plugin for max 9 and have problems to render in DR.
the client does not render the RF Mesh of an animation frame at all. Seems like the information is not transferrred to the client …
If i convert the RF Mesh of that frame to editable Poly everything is fine again. The RF Mesh of that frame gets rendered in DR
I tested with MR to find out if it´s a realflow problem but MR does it.
so someting must be wrong withe Vray i guess :shock:
Vray RC3
3DS Max 9 32 BIT
xp 64
e6400 Dual Core
odd. I assume all the rendernodes have the realflow plugin installed. Perhaps try copying over the mesh files seperately They may just may not be proeprly picked up by the nodes.
… the plugin was installed but i had to restart the spawner :sweat_smile:
now it works 8)
thanks
Klaus
