Hi all -
I’ve read older threads indicating that Vray cannot do motion blur on Realflow meshes - just looking to confirm that this still applies with the current versions. It seems to since I cannot get it to work, but just looking to rule out user error (always a good idea in my case)
Thanks!
b
Mblur works fine with new Realflow, but there is some limitations.
Length of blur or shutter speed shouldn’t be over frame.
(if your project is 25 fps, you shouldn’t use shutterspeed lower than 25)
And if I remember right, you should save realflow simulation with mblur channel.
-LarsSon
Thank you LarsSon - I will see if I can find the mblur channel in Realflow and give it another try with the appropriate shutter speed setting as well.
b
