Realistic vegetation
Hi.
I am trying to create realistic vegetation, but the results that I achieved is more “plastic vegetation”.
I use the Chaos Cosmos vegetation, but I get not realist leaves, and bark looks really fake, the grass is like plastic…
What can I do to get realistic results? Do I have to buy others packs vegetations or the one from Chaos Cosmos are ok?
I must say the new vegetation from Chaos Enscape looks really fake, they look like plastic…but probably its me who have to change the material.
But with some others assets from Chaos Cosmos without doing nothing, is just to download and place, they look really realistic, assets from “Max tree” “xfrog” they are good and realistic.
May thaks
Generally you need to pick a method which suits the scene, as although things are quicker these days, there’s still a render time trade-off between realism and ‘good enough’.
There are plenty of resources available to look at, to see how things are set up for leaves, for instance Jonas’s video here https://youtu.be/e2KqOfraUyw
Tree bark will need good base maps and displacement/normals to look good close up.
Use a more complex setup for foreground ‘hero’ stuff, then a simpler method for big scatters to avoid high render times on stuff that’s just too far to notice a big difference, especially displacement. :slight_smile:
If you’re rendering for images, consider using ai to enhance them. The results will often be far more realistic, although harder to control. Using a program like comfyui you have many tools like i2i, upscaling, control nets, etc. I’m actually slowly starting to replace my rendering pipeline with ai generation. Using only rudimentary renders (ie. clayrender from Vantage) to control the camera.
Thank you so much Puznowski.
I will try to use the ai.
Many thanks
