Hi there I’ve been busy with this apartments rendering, but I’m not having luck trying to set up a good sky for this window, can any body help how to set up it?
this is my rendering
and I want it to have this photoshop effect how to achieve?
image from facebook profile : revival design+vfx studios
I know this is not the “correct” way to do it but increasing the exposure ALWAYS over exposes the outdoor scene. I usually just increase the sunlight multiplier if I want to balance the interior and exterior exposure. Lowering the background multiplier doesnt work as you just get a grey image.
well i figured out, i change the inclination of the camera, move it to a lower position, and place the target a little higher, then it alows me to use a different texture in the mesh with the clouds. It stopped pointing to an endless sky. Ill post later the resulting images.
Hi leobonilla1985, the answer of your question is complex. The brightness of backgrownd image is sun position dependent. In your case may be you should set Background / Sky / default / overide checked. If needed you may increase Intensity mult option. Also you may adjust - Shutter speed, F-number, or Film speed. Its a question of tests. I wish you success
