I’m having a weird behavior in my library. (I’m using Enscape in Revit. :revit: )
When I use Asset Library I see about 15 assets that I have made recently.
If I open the Custom Asset Editor, I then see the 100 extra assets I have made in the past.
I think I have some type of library file error because I tried to consolidate working folders.
Is there an easy way to rebuild my library file?
Will it maintain the asset GUIDs so that files with Enscape assets saved in them will be able to pull the proxy content in Enscape correctly?
@Pieter_2 Maybe you know why this happened?
EDIT:
Since I had 2 Categories .jsons, I had to combine their categories into one file because certain assets were using Categories from the previous location.
I deleted assetCategories.json so it could be rebuilt.
I went into my user AppData and deleted the Enscape folder. (This will prompt you to path the asset library again because it’s like the first time you’ve opened Enscape.)
I’m still having issues with a few specific assets, but I may just delete and rebuild them. They are new, so they don’t live in any legacy models yet.
