Did somebody use 3ds max 2018 and Corona 5 on Rebus Farm? I got an error that files coronamaxutils2018 and coronamax are not supported, its weird because they said that REBUS supports all that software..
any ideas? I already wrote to the rebus support but no reply so far..
OK, I figured it out.. on the new or resetted scene is ok no error, so I just merged my scene into new scene
(maybe because I was previously working on older corona)
I had the same problem.
Rebus sent me this solution, and it works now:
Please try to manually re-install the Rebus plugin for your 3D application(s):
- Please make sure your 3D application is closed.
- Open the RebusDrop Preferences.
- Select the 3D software you use and click “Remove” also check and delete it manually from the folder you installed it.
- Select Add Applications in the tab Paths.
- Select the 3D application entry in the list.
- Click on Re-Install Plugins.
- Save, run your 3D application and submit a small test job.
