recent finish work
Hello , this is the first time i post here in vrayforum since 2003 when i became a vrayadict. C&C are welcome . this work was done in viz2006 and render with vray 1.46.15.The work was for an arquitect.
I wish you a merychristmas a happy new year - With Vray!!! :stuck_out_tongue:
Hello , i know you are very busy people , but i´m loking for ways to improve my work so if some one could give me some advice in a way to get better images i would be so happy :lol: :lol: , thank you for your support.
they look cool. not sure about the zombies walking around tho :slight_smile:
maybe you could experiment with different camera angles, including ones that are at a snails or birds eye height? try some DOF too.
Thank you nvanherpt i will try what you sugest and post result later.
about the DOF i have never use it do you have some sugestion for the parameters of DOF ex :for a 35mm lens Aperture ? Center bias ? Focal distance ? get from camera or don´t ? .
regards
maybe try doing the DOF post as it wil save render times significantly. Use Z-depth in hotoshop to do this unless you know how to do it in a copositing program.
We use tehose same low poly people but try to keep them to teh background so as to avoid the Zombie look :twisted:
all the shots are from teh road , is it possible to show something new?
but nice all teh same :smile: :smile:
hello momentum , thank you for your tips , i´m trying to use the DOF in vray i have made some progress, but i would like to know more about the z-deph, were can i find a tuturial to use it in photoshop, son i will post some new camera shots and without zommbies :lol:
thank very much for you support
Merry Cristmas and a happy new year for all !!!
If you want to use DOF in ps i can recommend Richard Rosenmans plugin
it is really affordable and easy to use.
all the info about rendering z depth is on his web site in the faq area
i have found this plugin the best thing i have bought this year,
talk about pluging a plugin :roll:
http://www.richardrosenman.com/dofpro.htm
thank you marcoos i will try Richards plugin.
