which is the recommended nvidea driver to use?, for no problem with gpu…
Recommended NVIDIA driver for V-Ray GPU is version 436.30
Doe’s it mean that this driver is ok for older V-Ray versions too? I ask this because VfR isn’t released so often and I afraid diver and V-Ray version needs to match or not?
Hmmm… IDK. On the top of the Chaos GPU page has the recommended driver listed.
Right, but doe’s this driver works for any V-Ray version? One plugin version is released day 1 an other day 10 and the next day 40. During this time the recommended driver number is changing. Doe’s all V-Ray version works with the latest recommended driver or doe’s driver and V-Ray version need each other?
Should be valid for all latest V-Ray versions per product. If you experience problems with the suggested driver, please report.
@b.maio_SGA Here at Rhino 6 / Win10 / driver 436.30 / GTXx080ti the denoiser works. Maybe the card is the problem.
Doubt its a hardware problem. Its CUDA supported. Worked fine for me in the earlier Vray for Rhino update 1 version.
B Maio
Unfortunately this is a hardware requirement of the newer NVidia AI Denoiser - it requires Maxwell or newer GPU architectures. (Chaos Docs)
Yavor
Hi Yavor,
Thanks for the notification. I guess my card just got obsolete for the new Vray. Very disappointed. I guess, I can do without the new Denoiser for now.
Good day
B. Maio
The V-Ray denoiser is still compatible.
