Recreating a lighting effect
I’m doing an interior scene and my client wants these types of lights -
I’ve tried Natty’s photometric method but no luck. Can anyone suggest a way of recreating this effect?
Zap
Hi Mark
how many different ies files have you tried ?.. if you can find out what lights are used here then you can get the right ies file to create that affect.. :wink:
The manufacturers aren’t returning my calls… :frowning:
Hi Mark
Well i just had to search for a good ies. so first i found a nice ies viewer on the net, to see a bit of ies, before loading it into the scene. it gives you a good visual feedback. :smile:
its free, just load it from my website !
http://www.tom-schuelke.com/pies.exe
hmm what also would be better, a programm to draw your own ies file and save it. this sometimes would give much better results as browsing dozens of ies files that still dont fit.
Greetings
Tom
by the way, here on the forum there are some good links to ies files.
just search for : ies, natty, i am sure you will find what you need.
Tom
yeah good one Tom.. ies viewers are a god send when you have a 1000+ ies’s.. :wink:
Hi Natty
allways nice to give back a bit of the help this forum gave to me. :smile:
Now , do you maybe know a program to draw your own ies files ?
i am just searching for something like that.
Tom
Thanks Guys. The IES viewer will make my life a lot easier
:smile:
no i dont .. but that would be pretty good
As far as I know IES files are photometric readings taken from this huge capsule shaped device that maps out a few parameters of the globe. To draw your own I’d suggest just using a combination of decay and attenuation parameters along with a subtle, or not so, projection map. You could probably get pretty creative with this method and it may not be accurate but neither would drawing your own photometric data.
Now that I think about it…
what is photometric data in laymans terms? Do you guys think it could considered the filament power and the refracted caustics of the bulb itself?
--Jon
maybe this is what you guys are looking for:
Photometrics Pro (for free?)
Manufacturing Software – CPQ, PLM and CAD - Revalize ($$$)
greetz
googlemans
Hi all
Well the point of drawing your own ies is simple.
For example i´ve loaded a ies, from one of nattys tutorials here from the forum. It has a very expressive ies file with strong and good lightpatterns, that fit perfect into a room inwhich for example you show photos or drawings.
Well i loved the lightpatterns, but on the inside of the airbus cabin for the flightcrew, that i do by the moment, this ies is much to spread through the very small cabin.
only thing i would like to do is some sort of bezier thing on a simple paper, draw the outline of my ies as i like it , and see what it is like.
when you´ve seen some dozens of ies files withtheir light contribution curves you very soon get a feeeling for their behaviour and look in renderings i think.
hmm. Do you all remember, wasnt in lightscape something comparable ?
I think i remember there was a sort of 3D thing with points you coud grab and move.
i think i will install this old saurier tomorow to have a look.
Hi googlemans. I am not sure if your links have what i need. but i will have a look at them too. thanks. :smile:
Tom
There are also more IES links on my site which you are welcome to browse :slight_smile:
-dave
wow an ies viewer :shock: :shock: :shock:
:smile: :smile: :smile:
thanks all
Yes you are right Tom, Lightscape did have a light/ ies modifier… there must be something like this on the market … perhaps the lighting development company’s have something like this ?
:smile:
A guy called Karba has made an ies generator,
http://www.3dcenter.ru/forum/index.php?showtopic=19113&st=0,
havent tried it out but it looks good.
Hope this helps..
:wink: HG
Hi hughg
nice website :lol: i didnt understand anything (russian ?).
But the immages are nice i think.
Which link is the download link for the software ?
Well i ll see. i hope the explainment isnt in russian.
But many thanks
Tom
wow this has some good possibility’s to be very good … a bit linear at the moment … but good :wink:
Hi natty
looks good i think. He i think we should make up another new part of this website where we could post all these nice things together.
i often search back in this forum becaus i knew here and there have been nice goodies or materials and so on.
this could be a bit better organisced. And with this nice community it could grow to a helpful thing.
tom
yeah like a share section .. apps, mats, so on and so on
