Hey Guys, just noticed this the other day. I had a light hanging from the ceiling, which I used a rec. light under it. I made the rec. light invisible but in the mirror directly beside the light on the wall the rec. light is visible.
anyone elts experience this?
Re: Rectangle Lights Reflection
Hi Sheldon
Under the light properties disable the affect reflection option.
If you make the light invisible, you are making the light invisible for the camera not for the reflection. In order to hide the light for the reflection you should disable the affect reflection option.
Best
