i finally changed to max 7 and suddenly i have this problem:
red dots on reflective materials !!! vray messages say: material returned overbright. it just happens when i have a gardient ramp or a bitmap in the enviroment slot. with pure white as reflection colour the dots are gone.
i also tried the “apply cropping script”, no changes ! all materials are vray materials.
i use max 7 with the latest vray version (1.46.10)
You have applied a camera correction modifier and kept “max compatible shade context” checked - if you uncheck, everything is fine.
It renders much cleaner that way as well.
ive had that bug before too and if you want to hear something even more freaky. i wasnt using the camera correction modifyer however i had a gradient ramp for my sky and i had it turned 90 degrees. this bug turns up with the gradient ramp at 90 degrees. have it at 0 degrees and the red spots go away.
there should be a list on the help page about these sorts of issues. AND they should update the help pages to have the same settings that is actually in v 1.47.03 or whatever else is current. In a few years down the road it’ll be 1.5. lol
