I started noticing that when I change the render quality settings, up or down, I often see a red flash in my preview - it wasn’t a problem at first but now it has started appearing in my videos too. I’ve reduced the output quality down to HD and I still see it (4 times in a 20 second video!). My nvidia 3060Ti should be enough to cope with it I’d have thought
I am sorry to hear about that @Grizzler , and thanks for the report.
Can you right away please submit a few example screenshots of this behavior if possible?
Furthermore, definitely make sure that you also have the latest drivers installed for your 3060Ti, which you can (and should) acquire directly here.
If that does not make a difference, please also submit us a Feedback Report as detailed here, so that we can also check the submitted log files for any hints that may explain this behavior at hand. Kindly let me know once you’ve sent it in too.
Just to make sure, does this occur still after you’ve updated your graphics card drivers? If so, then we’ll definitely require that Feedback Report ideally too as mentioned.
If anything it is happening more now since the last update, but it has been happening for quite a long time, at least two driver updates and two Enscape updates previous
Alright, in that case, we’ll investigate your log files too after said report has been submitted. You can let me know once you’ve done so and I’ll also have a look.
Now that I’m looking out for it I’m seeing it much more, you can see on this screenshot that not only is there a red flash on the metallic components, but there is a pink flash on the trees which are from the asset library - this is from a different project to the previous one I mentioned, but it happens in all of them.
SketchUp 2021 Pro
Enscape 3.3
GPU Drivers are current
A colleague of mine is experiencing this issue within the Enscape Viewport. It appears to happen if a change occurs that requires Enscape to recalculate. For example, adjusting light settings or adding a new object. The red flash is only present for a brief moment making it seem like its recalculation bug. Oddly enough the issue has occurred in other files but in very rare cases so it’s difficult to narrow down what the root cause is.
Curious to see if anyone else has experienced this before?
See the image: with quick hands, we got a screen capture :huh:
Cheers!
I get this a lot, but only recently (last couple of months or so)
If I pan the camera away and then back the pink eye will be gone, if l render the view, even with the pink eye visible it WONT be in the saved file. If I edit a material; especially a reflective one; then the pink eye will magically appear 80% of the time.
I’m running SU22 latest, Enscape latest and Nvidia driver latest.
I’m afraid it seems that we have not yet received any report from the e-mail you’re also using to sign into this Forum. Even if the log files do not show us more, it’s still good to have an overview of your machine and such. So pardon for having to ask again, but please very kindly submit a Feedback Report.
Also, does this behavior translate into your renderings, or is this only occurring in videos?
The same goes for you in this case.
If you haven’t submitted us a report, please kindly do so and let me know once you’ve done so - I have not been able to reproduce this behavior at all currently on my machines so again, any further info may help. Do you actually see this behavior translate videos as well like Grizzler?
Hi @jtubb , I hope it is okay that I’ve moved your post into this collected thread. I’ve adjusted the title as well to reflect your input too. As with the others, your colleague can gladly submit us a report as I’ve not been able to reproduce this on multiple machines.
If it may be project related, it would also be great to receive the scene in this case - Should there be any chance, especially if this occurs only in a specific one. Let me know if that is a possibility and I’ll share a confidential upload link with you.
Thank you in advance, and I appreciate the input so far.
@Demian_Gutberlet I’m out of the office this week but I’ll record a video and send a report next week.
I haven’t bothered with a report so far as it hasn’t really bothered me too much and I fully expect it to disappear with an Enscape and or driver update.
This has happened to me on a number of projects across multiple modeling platforms and Enscape versions. Sometimes it goes away when restarting Enscape, but not always. I’ve done a tiny amount of experimenting and it seems to revolve around fully or partially transparent materials. It is very annoying and you aren’t the only one experiencing it.
I attached a similar “glitch” along the same vein as this. Although this red line doesnt glow, it isnt suppose to be there and can be distracting if a client notices it. I have no clue how to elimate it.
I’ve just sent it. I think it’s just videos and previews and it seems to be worse when there are reflective materials present.
Same here
Sketchup 2022 Pro
Enscape 3.3
Next job I will submit an error report .
Any updates on this bug? We’re still seeing this appear in 3.3.
It didn’t occur to me since I turned Hardware Accelerated Ray Tracing and Deep Learning System Sampling (NVIDIA DLSS) feature off.
I turned DLSS off yesterday following another post and haven’t experienced the pink glow/flash since.
Give it a try, the worst that can happen is that you turn it back on again.
I’ll give it a go, thanks. Did you notice a significant increase in render times?
BTW, your solution worked a treat, thank you.
