RED LIGHT issues in distributed gpu render
I’m testing now the new vray 2.3
I have 2 identical systems with 4 GTX580 3GB each
Launching a gpu render in distributed mode the slave machine renders some parts in red.
If I render locally on the two systems the renders are ok
If I activate the render using both systems the first system renders ok, the second system send a red image
If I invert the test slave-master master-slave I got the same results.
Show mask is deactivated (!)
I repeat: two identical systems, same hardware, same drivers.
COLOR CORRECT PLUGIN!..is the cause…
That’s a bit odd… can you get me the scene?
it’s an huge scene. I used colorcorrect plugin, the latest Max 2012 64 version.
It produces reddish render only in distributed mode.
