Red Wavy Lines in render OCIO file
Hi all, ran into a problem with vray in maya using a ocio file. I believe I saw this question get asked like a year ago, and I think the solution was: it was supposed to be fixed in the newest update.
Well it seems I’m running into the same problem but running on the latest update. Red wavy lines in the VFB. Viewport render is completely fine. Saving as certain file extensions will solve it. For example: Saving as .exr will remove it, but say if you save as .png it will show up.
This has to be a vray issue rather than my OCIO file.
It is a known issue that is already fixed in the internal nightly builds. It will be implemented in the stable ones soon enough.
Yes I just saw there was another thread asking the same question. Sorry, didn’t see it. And thanks for that. I switched over to the nightly builds and its working good now.
