Redshift Material Conversion
this isn’t necessarily a Chaos Group issue, but Megascans now offers C4D support for Redshift and Standard, so i’ve been importing things using bridge, but if i have corona set as the renderer, it will import with redshift materials applied. I can change to standard render engine and re-import, then convert using corona converter, but only the diffuse slot stays intact. Would be much easier if we can convert the redshift material so I don’t need to relink all the maps in the material.
