Reduce flickering
Hello
This option will open the image blurred, and the flickering situation has not improved very well
Below with comparative files.
Hi darling_my,
At how many samples are you rendering the sequence? The ‘Reduce flickering’ option is not very suitable when dealing with very small details and sometimes(as in your case) blurs them significantly because the denoiser determines them as noise.
Alexander
HI.Alexander Atanasov
The sampling of these two images is 2000
Also, about the problem of animation flickering, is there a good solution?
