Reflected caustics on building
Hi guys!
I have a problem with water caustics. As you can see in the attachment there is so much noise on the building facade, but on the L-shaped plane in front of the rendering, the water caustics are clearly visible - noisy, but at least it is possible to see caustics drawing. In the background, on building facade there are just white, big noise dots which are unacceptable in final render :frowning:
Some informations about scene:
  • sun&sky light
  • default render settings
  • basic water material + noise connected (bump) - screen in attachment
  • bacic coronaMTL on building facade - correct abledo value
I have tried everything. Noise connected to bump, displacement, creating 3d noise with basic water material (no bump mapping) without any good result. The L-shaped plane in front of the image is just for test - will be deleted anyway.
Thanks for any suggestions!
I think if you’d move the test plane to the same position where the building’s wall is, you would get the same result - too noisy caustics. The reason is the distance from the water surface. Caustics are not laser - with distance they get more blurry and probably at some point there is not enough photons emmited to converge to meaningful solution. I would try to play with caustics settings, but i can’t give you more specific advice here.
What do you mean excatly? To play with connected noise bump map? In render settings there is just “enable/disable”.
I don’t have Corona now, but IIRC when you enable caustics solver, there should appear caustics settings rollout in performance tab (or maybe you should enable it in dev/experimental rollout). Hopefully someone from support team will tune in and will guide you further.
Which version of Corona is this? There were some improvements in V6 dailies if you would be willing to try that - https://coronarenderer.freshdesk.com/support/solutions/articles/5000570015-corona-renderer-for-3ds-max-daily-builds
Other than that, could you share the scene with us? We could then try to optimize it / see what the issue might be.
Uploader: Chaos
It’s Corona 5, 3DsMax 2019. I’ve uploaded the file :smiley: I hope there will be some good news!
edit: filename - Successfully uploaded as 1594741487_caustics-scene.zip
Here are some experiments:
note1: I lowered the resolution but the improvement should be independent from that
note2: all images were rendered with 3 min time limit on a Ryzen 3900X
  • reset render settings (I only did it to have a “fresh start”) - render setup > scene > reset settings
  • enable caustics in the Performance tab
  • disable “Generate caustics from environment” in Performance tab - since we mostly care about the caustics from sun
  • set GI vs AA to 8 - caustics are calculated between each pass and lowering this allows more passes to be rendered within the given time = more caustics re-calculations
  • set light samples multiplier to 1 - this does not lower the quality in this case and makes rendering slightly faster
  • set Max sample intensity to 10 - again, small speed up and no visible bias
  • experimentally changed water material’s reflection and refraction glossiness to 0,99 - this makes the caustics a bit more smooth, but also blurs the refraction and makes reflections darker - optional
  • experimentally re-rendered in 07.07 V6 daily build - virtually no visual difference in this case
  • experimentally enabled development/experimental stuff rollout (https://coronarenderer.freshdesk.com/support/solutions/articles/12000021288) and increased the number of caustics max photon / iteration from the default 5 000 to 25 000 - note that this will always improve caustics quality, but will also make rendering globally slower and may cause running out of RAM
I am attaching an archive with all renders here. I hope that helps!
Pozdrawiam,
Marcin :smiley:
caustics-renders.zip (10.2 MB)
