Reflection Bug
Hi all,
you can see below the result of a rendering with Enscape. The ceiling material is set to 100% roughness, 0% reflection (tried everything). There are point lights set with rhino, directed to the floor. Everything is blurred, no shadows on the ceiling.
Anyone knows why?
Thx, Jumbo
With spotlights hidden, the problem still exists:
Emissive Enscape material for spotlights turned off, still blurry but better:
@jumbo , what you see there are so-called “fireflies” which can especially occur when emissive surfaces are used for lighting. We generally always recommend using light sources themselves to light up the scene and keep emissive surfaces more as decoration, or at least make sure the main light sources are brighter and fill out the scene.
