I’ve noticed strange behaviors with AlSurface shader since have been using V_Ray 5.
The main one is this… The 2 images have exactly the same light, shader, etc… The only difference between the 2 is the “Focal Length” of the camera… Am I missing something? Thank you.
Is it possible to forward this scene (or a simplified one with the issue reproducible) to support@chaosgroup.com for further investigation? Make sure to mention this thread in the email, thanks.
Thanks for the provided files. We’ve managed to test the scene and the issue appears to be linked with the SSS Mix value when Reflection Strength 1 and 2 are set to 1.000. If you set the Mix value to less than 1, it seems to work properly - you can use this as a workaround for the time being. I’ve reported this in our internal bug-tracking system (ID number: VMAYA-9941) for developer investigation.
