Since Corona switched from LegacyMtl to PhysicalMtl, I’ve learned to use PhysicalMtl and I’m generally happy with it, especially because it adds features that used to require the use of LayeredMtl for example. However, what I regret is the impossibility, as far as I know, to modify the color of a material’s reflection because this option has simply disappeared.
Sometimes I want to assign a particular color to the reflection slot, which is possible with LegacyMtl but not with PhysicalMtl anymore. I know it’s not a PBR approach, but from an artistic point of view, it’s sometimes desirable.
Is there any way to alter the reflection color of a PhysicaMtl without altering the diffuse color as well?
Yes, it can do the trick, but the result is still very different from LegacyMtl because the diffuse color is also affected by the clearcoat, but that’s interesting, thanks.
As long as the developers keep the LegacyMtl in future versions of Corona, it’s not a problem, but if it were to be abandoned in the long run, it would be an issue for me.
