Interesting. I have a material converter that converts Autodesk materials. I’ll try that.
Best way to check if your scene has materials that aren’t up to the task is using the zorb script, you can see all types of materials and maps used in the scene (beware that for complex scenes you need some patience). You can also select the objects then that could have these incorrect materials applied. Zorb has in many ways saved lots of time debugging scenes.
The FixUtilities also checks, which I used looking for Raytrace materials, but didn’t find anything. Question is, why do non-V-Ray materials cause such havoc in V-Ray?
Because they are non-Vray materials
VrayMTLs are optimized, and Vray knows exactly what they can or can’t do. Chaos has the ‘translator’ for Standard (3dsmax) materials, but they can’t make a translator for every tropical material there is from other packages or render engines. It wouldn’t be feasible or optimized.
That is fine, except I converted to Corona and it rendered fine and then I tried the UMC convertor in V-Ray and that fixed it.
So the problems are gone? Good to hear. Indeed it wouldn’t hurt for the converter to have more options like the corona one has, even the option to change the assigned renderer to Vray when converting for instance, should be there, like Corona’s converter.
Yes, the problem is gone. I didn’t think it was a material thing, because a gray override didn’t solve it. Converting in Corona worked and so did the UMC in V-Ray. All is good.
I was having a similar issue with an interior scene. Light select and reflection elements were ridiculously overbright and noisy. Only happened on one specific camera though. Replacing the camera fixed it, but then it happened again.
Yeah, something weird is going on. Turning off my Forest Pro solved it too, but I used the same trees and Forest Pro on many others scenes without an issue.
We have received the scene from @glorybound and using the latest stable nightly build there are no artifacts. In the successive V-Ray Next update, it should work also.
Autodesk material → Vray material conversion. The thought of it makes me squirm honestly. I never convert materials.
For peace of mind I just start with fresh Vray materials every job, if I don’t already have what I need in my library that is.
I second that.
What was the problem? I installed the nightly and I’ll let you know how it goes. Thank you!
Since V-Ray Next Update 1, some of the render elements are rendered differently than before. All direct reflections of lights now go the Specular element and all indirect reflections go to the reflective element.
Could you check also the specular render element? You can find more about consistent render elements in our documentation.
https://docs.chaosgroup.com/display/…pertParameters
