Reflection map issue
Hello, I got a problem. Live link from 3ds max and Corona won’t show me properly the reflection map when I got also a diffuse map in the material. (tried with legacy and physical mat) As soon as I detach the diffuse map the reflection map will show it properly during the live link, but of course I got no diffuse there.
The only way I achieved to show the reflection map correctly is when I export the scene in to .vantage file and open it in Vantage. So the question is, what’s going on with the live link??
Hi, can you please clarify what exactly you mean by “reflection map” when using the Corona Physical Material? Is it roughness/glossiness, IOR, metalness, or something else?
I need this information to verify if this is something new or if we already have this logged as (CMAX-1460).
Hello Marcin, I mean a texture you put in to the “Base roughness” slot. I also tried with Vray and LiveLink and it worked as should, so it remain only as a Corona - LiveLink issue.
Thank you. This is already reported and should be fixed soon. Unfortunately, I am not aware of any workarounds other than exporting to Vantage.
This is fixed in Corona 13 Hotfix 1 - Chaos Corona 13 (Hotfix 1) now available for 3ds Max and Cinema 4D - Corona Common :: Announcements - Chaos Forum
Diffuse + roughness should be working fine now, but there are some combinations which may not be working correctly yet (e.g. roughness + IOR or roughness + metalness). We are working on fixing this as well.
