I’ve got a really simple question, I’m sure someone has to have run into this before, but how do you render a reflection pass in vray? Do matte objects work differently when using HDRI and GI with reflections, shadows seem to work fine, but no reflections
If your using a vray material wrapper to do your matte material i suggest puttint a vray material in the empty material slot. this will a: control color of the GI comming off of the matte. and if you turn on reflections it will also lend reflections to the matte. i suggest though putting a black color in the environment of that vray material. its very fussy though. the reflections are cut out in the alpha
hmm… well i’ll give it a shot, i might just set local environ mats to cut down the reflection coming in off the hdr mat and comp together the other elements, might give a little more control.
