Hi all
I have search for a while, but not found such a topic…
I am rendering a simple scene of a bad as you see below.
I have Vray light on my window. The question is why through the window i can see the sky and in the mirror i have this white reflection?
Many thanx in advance!
You need to enable reflective gi caustics, which I believe are off by default. Not the photon caustics - the ones in the Indirect Illumination (GI) rollout.
Thanx all for your replies…
I have tried a couple of things but the true is that by the Vray lights there is a Affect specular option. When the option is off everthing seems to be all right.
I wish u good luck!
I will post the result in the Image uploads section.
C u around!
