Reflection problem
Hey guys, I was using corona in one of my projects, where there is a mirror in front of the window as you can see in the image,
the reflection of the mirror is the environment i used to light the scene, i tried adding a background and i tried using the overwrite reflection and visible environment in corona, but i still get the same reflection, i also added a plane on the window with the environment image on it and it will show the same result,
My mirror material is pretty simple no diffuse and reflection 1 Fresnel 25,
if you guys have any ideas that would be grateful,
Please not i don’t want to add any curtain on the window
If there’s a glass pane in your window, that has material with refraction, then you have to override refraction, not reflection, as everything that is seen through that glass is treated as refraction.
ahh i get your point, but wouldn’t this affect the lighting ?
No, it won’t. Why would it?
Just tried it, works like a charm, thank you very much, much appreciated :smiley:
