Hi I need Reflection refraction filter for post-production
like render pass in vray
so how can we create it? because in need alpha make just for reflection
Please see here: https://coronarenderer.freshdesk.com/support/solutions/articles/12000066916-how-to-use-masks-with-reflection-refraction
In order to utilize propagation of masks, you will need to have Corona v.6 DB installed, you can find the latest daily build here (18/06/2020): Dropbox - Error - Simplify your life
hi thanks . I feel that you did not understand my question correctly.
I know render element. I search a way for reflection refraction mask.
that’s my protfolio
I am afraid we do not understand your question correctly, because you never correctly described what exactly you would like to achieve. Can you please clarify? I don’t think “I need reflection refraction mask” + a link to your portfolio is good enough. Can you please give us a bit more detail what exactly you are looking for? Maybe an example how it works in V-Ray?
raw reflection = CShading_RawComponent set to “Reflect”
reflection filter = CSading_SourceColor set to “Reflect”
reflection = CShading_Reflect
It is the same with refraction. Hope that helps!
reflection = CShading_ReflectIt is the same with refraction. Hope that helps!
many thank. 100 % that’s my questions answer…
you are best…
You’re welcome! Always happy to help.
