reflection window
can someone please help me with this? There are spheres visible in the reflection of the windows, how can I avoid them and make the glass look more realistic?
Hello, birgit,
It is unclear from the screenshot you’ve shared what exactly is being reflected in the windows or whether there’s something clipping their geometry.
My suggestion is simply to hide the objects that are being reflected or if that doesn’t work, send over a couple more screenshots to better illustrate the situation.
If hiding the objects is not an option for this particular shot or does not solve your problem, you can try adding an Override attribute to the objects’ materials and place another material with an opacity value of 0 in the the Reflection slot to make them appear invisible in other objects’ reflections. Alternatively you can use the Override material for the same purpose. More info on this advanced workflow can be found at:
Again, this method is a bit more complex than what is probably needed in your case.
Kind regards,
Peter
