Reflection
I usually start my material reflection at 0,0,40 - is there a method to getting physically accurate reflection values without a texture map? Kind of like the IOR list you see floating around.
Reflections for what material? Why do you start with a blue color?
I’m guessing it’s not RGB values, rather HSV.
Reflection isn’t based upon material, rather it’s finish. For example you can have 2 objects made of the same plastic, one is matt, the other is glossy, so the reflection and glossiness values will be different.
Personally I start with reflection value around 0,0,125 and go from there.
There might be real world values for specific materials and finishes, but for what we do it would be pointless to try.
Doh! Of course it is.
Yea, not blue. Is there a chart somewhere? I usually look at something from a known library.
if its VRayMtl and Reflection Colour - physics says: RGB 1,1,1 float for dielectrics.
It would be nice to get a list of actual architectural materials, for reflection and IOR. Everything I have is seen is for metals. I need brick, stone, asphalt… architectural stuff.
look at any simplified pbr shader - there is no „reflection colour” input, its just hardcoded pure white in whatever colourspace you are rendering. the main control over reflections is ior/specular.
What I always understood is that reflection is set to pure white and any deviation from pure reflective or pure glossy, or however you term it (shiny to matte), is controlled by a map when you want to go granular
into whatever material it is. To my mind there can’t be one ior to rule them all for each flavour of material, as they’re all made from different ‘stuff’. Unless it’s a specific known absolute in an ideal state I guess.
Right or wrong?
Even with a map in the reflection slot, if any part is 100% white, that part is blown out. Now, to add to the mix, when does the glossiness/roughness take over?
why are you insisting on using maps in reflection colour slot? you were asking about „physically accurate reflection values”, right?
Doesn’t the color in the reflection slop work with the bitmap in the reflection slot. If the bitmap is white, black, and grays, and I lower the color in the refection slot, doesn’t that reduce the intensity of the of the bitmap? This is how the diffused slot works.
maybe this will help:
why default Corona shader does not have reflection colour input?
