We’re running into an interesting problem. The general rule with transparency and matting is that if you want your transparency to work (and not have halos around your objects) you need to render with a black background.
But when we follow this method, we’re getting less reflections from our environment when that environment is traced through an object with refraction
The second image (no-alpha-details.jpg) is an example with a VRay sky in the Max Environment slot and no VRay overrides. The glass is simple 1.6 IOR with affect alphas and affect shadows checked on .
Now, if we setup for a black background by putting black in the Max Environment slot and moving the VRay Sky to the VRay Environment Overrides, we get the first image (alpha-details.jpg).
Notice how there is significantly less reflection on the chair. As far as I can tell, it appears that the reflection on the seat is using what is traced from the refraction of the glass. In this case since our environment refraction is black (necessary to avoid the alpha pre-multiplying halos) we’re getting black in the glass refraction, and hence, black in the chair reflection instead of the reflection environment.
Is there any way to solve this? I would expect to get the same reflection results as in the first example, but I’m unsure whether this is a bug, or if it isn’t, how to achieve the same results.
But then we would have to set the environment on every material that might exhibit this behavior, correct? That’s incredibly tedious for an archviz scene where you can have hundreds of materials.
And I’m not sure what you mean by environment priority options.
In the VRayMtl Options rollout, there is an environment priority setting. It determines how environment overrides of different materials override one another.
In general unfortuntely, like with the matte/shadow stuff, there is no “logical” default behaviour for this; there are cases where the behaviour you describe would be unwanted.
Putting the VRaySky in the chair’s environment slot produces the same problematic effect. I assume this is because the chair is technically not reflecting the environment, it’s reflecting the glass.
Putting the VRaySky in the Glass’ environment slot produces the right effect on the chair, but brings back the haloing problem because the glass no longer has a black refractive environment.
Is there an example somewhere as to how to utilize the environment priority setting? The help files are rather vague and me flipping values is having no noticeable effect in this situation.
