I’m trying to match the reflected light (circled in green) in the photo attached. It is not showing up in the rendered version. Reflected caustics is turned on. I tried using actual caustics but it didn’t seem to change anything either. I’ve even tried putting a mirror surface there but it still doesn’t show up.
Any ideas as to what could be causing this to fail?
Please enable the Caustics in the GI tab and move the sun target more or less here: http://ftp.chaosgroup.com/support/2019-02-26\_15-13-42.png
The Photon emit radius value should be edited too (for example 10000mm starts showing some results on the wall).
So does vray have to reload the caustics map for each subsequent frame? I’m finding the file size is between 12-15Gb for a decent quality caustics solution. The load time is significant.
You’re right. It is a pain. And quite un-intuitive. Vlado did mention something in this post about making caustics a bit easier for update 2. Hope they work on making it faster too.
It can take a few minutes to pre-calculate, but it’s not really much of a pain to setup. I usually run it as a separate pass, so that if I need to adjust it I don’t need to re-render the entire scene again.
I had forgotten this technique, which just saved me a big headache on a project, so thanks for linking it here so long ago
This should really be added to the docs as an alternative technique, given that it is so useful.
As a side note the docs entry on caustics seems to be many many years out of date and contains errors and omissions.
