Reflective Material
Hi
What would be the best way to recreate the change in the tone of the reflective material ?
N
looks like a pretty simple falloff map to me. Likely I would use a falloff blue to red in the diffuse, then just standard reflections.
I would probably put the map in reflection instead. You’ll want to change the energy preservation mode to monochromatic though or you might not get what you expect.
I have to do this often to get a “soap film” look on clear plastic. Those glasses are more opaque than I usually have, but still, using reflection is a good way to do it.
Both would work though.
