Refraction and HDRI on light
Hello! Newby question… I have a simple Dome light with an HDRI. I apply a basic material with refraction. I was expecting to see the refraction effect of the HDRI on the object, but it doesn’t seem to be the case?
Would I be missing a specific toggle to activate?
In the attached image, the red line is the current behaviour, and the green line is what I’m expecting?
thanks so much !
Hi @martin_belleau , what you are observing is expected and caused by the default infinite behavior of the Dome Light. You can get your expected result by making the Dome Light finite (there is a rollout for Finite Dome options in the General rollout).
To give additional details - basically the result you are getting is determined only by the direction of the camera rays. Since the effect you expect, is based on the refraction of the material, and your object has parallel faces on both sides, the output ray direction matches the input, so for an infinite light you get the same result. Once you make the light finite the exact position of the output rays (after the refraction) starts making difference to the light sampling result.
oh! most excellent! thanks so much! this is what I was looking for !!!
