Refraction bug?
I think I found a bug. 3.50.04; an object with a refraction material where the object/camera is very far from the origin, you can see geometry artifacts in the refraction.
The material is just a normal vray material with high refraction/reflection. Artifacts go away if you set the IOR to zero.
Kris.
vray_refractionbug.zip (68.3 KB)
Try turning off the Embree raycaster. This should get rid of the artifacts.
