Refraction glossiness ??
HEY
What’s up with that ? Is it that complicated?
And what about FULL OPACITY MODE /texture support ?
Very necessary things​
Unfortunately Vantage supports only the “clip” opacity mode, so a single particular pixel can be only fully transparent or fully opaque. They’ve said in 2020 that might support the full opacity modes in the near future, which will enable Vantage to support the V-Ray Light material’s opacity. We’re in 2023 and that function hasn’t been implemented. They are more preoccupied overhauling the UI instead of implementing necessary things​.
Luckly there is a temporary workaround to achieve a render with gradient maps. Set the bitmap/map (but inverted) on the “Refract” slot and set the Refract IOR to 1. (That’s how I do).
What do you mean by “texture support” ?
Greetings,
Vladimir Nedev
texture support = OPACITY MAP. Normal mode…not just absolute black & white
@vasile_bulgac1 ​ gave an idea… ill give it a try
Hey @vasile_bulgac1 ​
Doesnt work for me
@vasile_bulgac1 ​ MY MISTAKE. Sorry . works just fine
Thanks !
