Hi guys,
I’m facing a big problem to render a curtain wall made of several glass elements. Looks like the refraction stop to be calculated after some bounces.
I alredy tried to rise the Max ray depth to 100, but the problem is always there.
Is there a way to rise the ray depth to more than 100?
I tried to test this wall on a simplified scene, with a simplified glass material (no bump), but the result is always the same..
You could try to play with exit colour in dev/debug rollout and see if you’d be able to achieve better result. An option to use enviroment as exit colour, would be even better solution - i asked for this long time ago, but without much success.
