Is it possible to create refractive caustics using Vray for Blender, and if so could someone give me some tips please or poit me to a tutorial.
Cheers, Wig
Cheers, Wig
@Stugys good suggestions about the caustics settings, thanks! I’ve set up caustics before but had trouble with the right values. Here’s a simple test, hope this file helps you Wig42. Not sure if it’s obvious, but you have to enable caustics in the render settings.
you are welcome, yeah i was forgot about coustics tick on, and if you whant more reaism, tick on “Enable dispersion”
