Region Render + Denoise After
I’m not sure if anyone has figured out how to properly render regions as I have trouble denoising them.
-Denoise mode - Gather data for later-
42pass render > Save CXR > Load into CIE > Post + Denoise
42pass region render > Save CXR > Load into CIE > Post + Failed Denoise (Error: Denoising has failed. The image has to be rendered with at least 2 passes.)
CIE cannot denoise regions, I will update once I find a work-around.
2 Options so far
  1. -Denoise Mode: Gather data for later-
    Save in History > Create Regions > Pass Limit 4 (any number above 2) > Resume Render > Save CXR > Load into CIE > Denoise will do the whole image but the regions will be denoised properly
  2. -Denoise Mode: Full Denoising-
    Create Regions > (Erase) Clear Frame Buffer > Render 42 passes > Save CXR > Load into CIE > Adjust denoiser
Both options still create lighting/shading/artifact differences in between original & regions.
I think region renders still have a way to go before becoming production ready.
edit: 2500px res
