Region Render - do not clear previous render
I’m pretty sure this has been asked before because I remember reading it a few months ago but I couldn’t find it:
When doing render region on VFB the previous render should not be cleared.
go to render setup>system>frame buffer and uncheck clear VFB inbetween renders. Does that solves your issue?
Maybe default to ‘not clear’ ? I manually erase, as necessary. Vs the ‘oh sh#t, I just wiped my screen’
Agree, I always turn it off.
Good Luck
You can always save your own defaults.
Thank you romullus! That’s it! :wink:
You’re welcome!
