It would be a really nice addition to have various colormappings per camera !
Which of the color mapping parameters do you need there? Also, should they override the main settings or vice versa?
Good question
I could imagine there´s a switch in the color Mapping rollout “Color Mapping per Camera” or something. Once it´s active the global controls
are greyed out and become available in the camera menue. As I only use Reinhard, Mulitplier, Burn Value and Gamma would be enough per camera. All the
other sitches like sub-pixel mapping, clamp output etc. I think are not neccessary and could stay global in the color Mapping Rollout.
It would be great if this finds its way into a future version. At the moment I often write down different Color Mapping values for different cameras in the file
properties and set them manually depending on the view I render.
I’d love this as well. I only ever use reinhard, so the value that gets changed per camera is always just the burn value.
+1 !
Reinhard is the only one I use & Burn value is the only one I change !
Anyway, “Color Mapping per Camera” is a great idea
