relative folder path
Hi, I need to use corona proxies with a relative path that first navigates up the folder structure and then navigates down the different folders. For that I would use path in form ../../../../ to navigate up. I have noticed that this way works only sometimes. And sometimes proxies are found when moved to different folders.
Do you know what could cause this problem?
Daniel
Has anyone tried this type of path definition?
generally relative pathing is problematic for us at the moment, but we will soon allocate a developer to look into it. It seems that the origin of the path (from where it goes up by ../../) is incorrect within our code. (as for example Corona Bitmap has the same issue, but Native Bitmap works)
Thanks for reporting, please consider this as an answer to https://forum.corona-renderer.com/ v7 latest build bugs as well, as they all seem to be connected.
Jan
(Internal ID=629861971)
Thanks Jan,
keep the good work on Corona for C4D, only bright days lie ahead.
