Hello Forum,
Not been using Enscape for long but i have a couple of questions that I cannot find answers to with a search.
when i add rectangular lights, and i extend them to my preferred length, after some time of working in the model the actual light emitted from them shortens, so in effect a certain proportion of the length of the rectangle light is no longer emitting light. anyone come across this before?
Is there a way I can set the depth of field and focal point on a scene by scene basis?
@GaryRead , welcome to our Forum!
- When it comes to rectangular lights especially, make sure to edit them using Enscape’s light size controls only - That is because there is a fixed limit regarding over which distance the light can be emitted. This limit is there due to technical reasons and is pretty much present in most real-time applications.
If you’ve already done that, and this issue still persists, then can you also send me a screenshot of that behavior? If the sources are also located on a wall or close to a wall, does it help if you increase the thickness of the respective wall?
- Yes! You can simply connect any of your Visual Settings to any scene/view:
https://enscape3d.com/community/blog/knowledgebase/link_view_to_preset/#createl
Thank you in advance for any further replies.
Many Thanks for your help!
