we are using relative paths in our projects for all textures and other assets, and we use Xref scenes, to bring all scenes in MASTER scene, and we also set path to xrefs as relative. it’s rendering fine on workstation. but once we turn on DR rendering, DR rendering just empty space, as there is no xrefs, only objects that in scene.
Hi, thanks for posting.
Could you render a test with only using your workstation for distributed rendering.
To do that, add the workstation’s IP address and disable “use local host” checker
If you render with no issues I would say the problem is with the network configuration to your render nodes.
